Inventor Forum
Using a ProE drawing template in Autodesk Inventor or AutoCAD
1 REPLY 1
arandmd
471 Views, 1 Reply
I customer sent me a drawing template I need to use to submit a drawing to them.  It is a ProE template which has a file extension of .frm.1  Any suggestions on how to open this file extension and use it using either Autodesk Inventor or AutoCad?  This would be greatly appreciated.
1 REPLY 1
Cadmanto
in reply to: arandmd
It has been a while, but I remember Pro-E and that file extension.  It alone is not compatible with Inventor.
If you look at the file types that are excepted this is not one of them.
What I would do is talk to the customer that supplied it and see if they save that template out as a .dxf file so you can import that and save that internally to Inventor as a template file.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
