Using a library for Inventor
tak.fujiwara
Observer Observer
tak.fujiwara
Observer
Observer
I would like to use the vacuum flange library such as "JIS_JPI_Piping_Content_Pack_JN_V1.1_2019" for my Inventor. But, this is not compatible to Inventor. Do you have a similar products ready for the Inventor?
Xun.Zhang
Howdy @tak.fujiwara I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
It is unclear for me about the library, are you talking about content center library?
Thanks!
Xun
johnsonshiue
Hi Tak,
I believe you are talking about Content Center Library, right? I am not sure if such content is available for Inventor. I need to check with the project team.
Many thanks!
Software Test Engineer
Frederick_Law
This?
Yes, that's what I want to use inside my Inventor. The Help Deak simply told that you cannot use it on Inventor. If you have any idea how to convert into a usable format or library, let me know.  Thanks!
jan_priban
All Tube&Pipe stuff (pipes, elbows ...) is stored in Content Center libraries. Currently we have 3 predefined JIS T&P styles . User can create/modify T&P style to achieve style he needs. Means he can define T&P style based on pipes, elbows from Content Center. But list of Content Center parts (we use term "families") is given. User can publish own parts/families into Content Center and then use published part in T&P style. But currently there is no transfer guide/wizard from Plant to Inventor (Content Center). You would have to create iParts based on Plant (standard book) definition and publish such parts into Content Center. Finally define new T&P style based on just published part (new families)
Regards
Jan Priban (the Content Center team)
