User defined Toolbar
smokes2998
Message 1 of 8
smokes2998
Hi is there a user defined tool bar like the SW S key in inventor
http://www.solidworks.com/sw/resources/videos/solidworks-skey-mouse-gestures.htm
I find this feature a life saver and with people going to much bigger monitor screens this would save a lot  of unnecessary mouse movement.
As there are more commands than there are keys on a keyboard.
Replies (7)
Message 2 of 8
Marco.Takx
In Inventor you can customize the Marking menu's for each environment below the righ-mouse button.
Is this something that you want?
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 3 of 8
mflayler
Just to expound on this...
There is also a CTRL+Right Click Marking Menu available for full customization.  It doesn't come up anywhere except 2D Sketching unless you customize the screen shown above for that Sub Environment.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 4 of 8
smokes2998
is this availble in inventor 2013? it still look like a huge faff to setup compared to SW and SE.
thanks
Message 5 of 8
mflayler
The CTRL menu was added in 2014.  Its really not that hard to setup, especially when you know the commands you want.  The radial marking menu in Inventor already does a pretty good job on its own.  Also in 2014 they streamlined the OK APPLY CANCEL options when in commands for the menu too.
Message 6 of 8
smokes2998
is this availble in inventor 2013? it still look like a huge faff to setup compared to SW and SE. And it limits you to 8 commands per an enviroment I want more commands per and enviromentradial menu.PNG
Message 7 of 8
blair
I use the SpacePilot Pro from 3dConnexions. Easy to have the commands I need for each environment on my motion controller. Plus it allows me to use my LH as well to control the movement on the screen.
www.3dconnexion.com
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 8 of 8
smokes2998
I am stuck with a space navigator as corporate don't want to spend the money on a 12 button 3d mouse.
