Use the space avalable in the prompt settings.
b_ruijter
b_ruijter
As i was trying to look at the prompt settings i noticed the column Propt Text was rather narrow but i can not stretch it towards the space avalable. I think it's a goog idea to stretch the column window together with the complete pop-up window. It would make things a little bit more organized. What do you think?
SBix26
You don't say in your message what version of Inventor you're using, but this is not what I see in Inventor 2020.  When I stretch the Application Options dialog, the entire Prompt Text list stretches with it, exactly as you are proposing:
Update: in 2019, I see the same issue that you illustrated, so it was apparently fixed in 2020.
Sam B
Inventor Pro 2020.2 | Windows 7 SP1
LinkedIn
mcgyvr
edit... seems @SBix26  found it true in 2019 but fixed in 2020..
Yeah it looks nothing like that on mine either..
Are you using a 4k monitor? What resolution are you at?
What version of Inventor?
