Use Inventor to Make Punch Programs
Hello, We are currently switching over to Inventor and I have a question about the capabilities of Inventor. We currently use AutoCad for our sheet metal drawings and we bring the drawing into a program called Striker to set up the program to punch the sheet metal on our LVD punch press. Can someone shed some light on Inventor if there is a way to make the programs using the Inventor software? I did try the Part Share add on which is used with the Striker software. The Part Share is OK but I was wondering if there was anything that Inventor has that would be better. Thanks in advance
swalton
Base Inventor does not make any CNC code.
The Product Design and Manufacturing collection includes Inventor Nesting which will nest 2d shapes onto material sheets.  It outputs a dxf/dwg I think.
The Collection also includes Inventor CAM, which does 2.5-5D CNC programming, but not punch presses.
Fusion Manufacturing does 2.5-5D CNC programming, but not punch presses.
I don't think Autodesk offers any solution for programming punch presses.
Steve Walton
Inventor 2025
Vault Professional 2025
Thank you for the information.
javiar
Hi @Anonymous ,
As Swalton mentioned, neither Inventor nor Fusion includes embedded tech. to drive punch presses. However, our more advanced Nesting solution - Autodesk TruNest - allows you to import models (ipt, iam, dxf, dwg, and other formats), generate optimized nests, and create postprocessed nc code to drive punch presses. And it does a lot more. Please visit https://www.autodesk.com/products/trunest/overview for more details on TruNest.
Ravi J
Ravi Javia
Product Manager
swalton
@javiar
The Autodesk Product Page that I thought listed all Autodesk manufacturing offerings does not show Truenest.
https://www.autodesk.com/products?filters=pdm-products--manufacturing-production&sorting=featured&me...
Should it?
Steve Walton
Inventor 2025
Thank you Ravi for the information. I did look at the link but I didn't see anything about being able to post process to a punch press. We typically run a single part on a sheet and do a grid pattern of the part. How would the tooling be determined for my machine for the nesting? Hopefully you can shed a little light on my question.
