Use an equation in CC custom expression
SharkDesign
Mentor Mentor
SharkDesign
The min and max of my Content Center part are different depending on which member you choose.
Is there a way to get this field to work on an equation using information from the part table?
I've highlighted the two fields I am talking about.
  Inventor Certified Professional
SharkDesign
Solved it, create a custom column range as normal and then edit the numbers after.
SharkDesign
I actually didn't solve it. It only updates when 'roundhole' is changed and not when "A_" is changed.
Inventor bug team tell me it doesn't work like that, even though it half works.
