Use 3d /2d Sketch to create a segment - cable and harness
eladm
eladm
Hi Inventor 🙂
When using Tube and pipe there is command called derived route  - I can use Sketch I made in advance to create the route (tube/pipe)
At Cable and harness - to create a segment  - do we have a similar command ?
I can create a points in parts in the segment route , but the tube and pipe command is better . To create the segment we need to RMB - edit offset or snap to points in the way , but the path can be complicated and we need to hide part or create a section .
regards
tobias
Hi @eladm,
You could just place a sketch part in the cable and harness assembly.
Then you can also edit the sketch outside the cable and harness assembly.
With sketch part I mean you can make a 3D sketch in a part environment.
Save that 3D sketch as an ipt file and insert it in the assembly.
Tobias
Tobias
The Netherlands
Inventor Pro 2026, Vault Pro 2026, AutoCad Electrical 2026.
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
eladm
In Tube and pipe there is command called derived route , it missing in cable and harness . The sketch need to be with points not 1 curved line
