Urgent! Export Assembly files from Solidworks To Inventor
Alexrose1942
Message 1 of 13
Alexrose1942
Looking for an effiecient way to export assemblies from SolidWorks to inventor , I just need them as solid bodies and not as surfaces, few companies I've worked with sending me assemblies files that were converted to .sldprt and when i open them they appear as surfaces and giving me a headache in multiples tasks and drawing visiblity problems. is there any Plug-In for SW to do this in an efficient way ? STEP act the same . please answer only if you really tested it as i dont want to mislead the guys there.. Thanks
Replies (12)
Message 2 of 13
mdavis22569
First ..what version of Inventor ...
ALso you should be able to open it right from Solidworks to Inventor...
If you're in 2016, you can use the AnyCad part of Inventor...
Mike Davis
Message 3 of 13
Alexrose1942
Inventor Version 2015 , they will not send the assembly as sldass files..
Message 4 of 13
mdavis22569
how will they send it ...
Mike Davis
Message 5 of 13
Mark.Lancaster
@Alexrose1942
Since you are using Inventor 2015..  First open the solidworks part by single select it from the list.  At the bottom of the open dialog, select the toptions button.  In the options, make sure self heal and the options next to it are selected.  I don't have Inventor 2015 currently running so I'm unable to post a screen shot of what I'm talking about.
Mark Lancaster
Message 6 of 13
Alexrose1942
@mdavis22569 they make sldprt from their assemblies and they send .
Message 7 of 13
mdavis22569
so when you open it you're getting surfaces instead of solids?
Mike Davis
Message 8 of 13
Alexrose1942
Exactly
Message 9 of 13
mdavis22569
did you see @Mark.Lancaster post ?        I don't have 2015 either to show you ...
also take a moment for this
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
can you provide a part so we can maybe screencast and show it ...
Mike Davis
Message 10 of 13
Alexrose1942
Message 11 of 13
mdavis22569
I'm only getting surface imports ...
Mike Davis
Message 12 of 13
Mark.Lancaster
mdavis22569 bet me to the reply but yes its only surfaces.  Either you will need to repair this yourself or ask for another file from your supplier.  See if they will provide a STEP file instead.
Mark Lancaster
Message 13 of 13
WHolzwarth
I regret to say, that derived single SLDPRTs made from SLDASMs are very often just garbage. This file is one of them. You can see that, if you're opening this SLDPRT with eDrawings.
Nevertheless I've tried to heal it. Here's the result. zipped as 2015 IPT and STEP.
Walter
Walter Holzwarth
