Updating Sketch Symbols
Hello everyone,
We are using sketch symbols for our revision blocks. At some point the text and block height changed between the old and new drawings (this happened many years ago). When we encounter an drawing with the old sketch symbols we have to right click on the revision, select edit definition, then manually change the text height and the block height. We have three different revision blocks (1 line, 2 line, and 3 lines). I've attached a screenshot of our 1 line revision block. The bottom row is part of our title block and the top row is from the sketch symbol. Is there a way to update these revision blocks to our current standard, perhaps with one rule that will work regardless of what revision block is selected?
Thank you for you help!
