Inventor Forum
Updating font size
1 REPLY 1
221 Views, 1 Reply
Updating font size
I noticed just lately, if I update the height of the text in my IDW through Styles Editor, not all the text in the document updates? Why would this be? All the text is under the text style "Instruction Text", but when I update the text height in the Instruction text style, only some of the text updates and I have to manually update all the rest?
1 REPLY 1
jletcher
This will be hard to find out for you without the data. There is nothing for us to check or try to find the issue. If the data set is small post it so we can open it and check it out. The only thing can be is the text style is not the same or when the text was made in the text dialog they change a few things like if your style is set for center and they changed it in the dialog to be left justifield the can cause this issue. So without the date set to dig into this is the best answer I can give you.
