- Mute
- Permalink
- Report
Im having a problem with copy design on inventor files that has an ilogic rule using a specific part name. The problem is the ilogic rule itself is being copied but the part name that ilogic is using is still using the original file name instead of the the copy designed file name that includes a prefix. This causes the ilogic rule not to work unless you manually go in and correct the file name which isnt worth doing over and over in my case. Is there a way to lock a component name in ilogic use that specific part as opposed to just looking for specific text you type in? I'm posting this to both Inventor and Vault forums because I'm not sure which program might provide a solution.
