Update Error Message
alanrichardson
alanrichardson
Can anyone help?
I get an error message when I attempt to install update 2020.0.1 update
(Error applying transforms. verify that the specified transform paths are valid).
I have no idea where to go now . . .
Alan Richardson
Inventor 2020, Windows 10
Mark.Lancaster
@alanrichardson
Don't use Desktop App for this..  Its bloatware..  Smiley LOL
Go into your Autodesk Account, download the update and install it from there.  If that doesn't work you will need to provide the installation log files for the update.
Mark Lancaster
alanrichardson
Hi Mark,
Thanks for the reply.
Tried that and still no luck  - another error message
Do you know where I'll find the installation log?
Alan
Mark.Lancaster
@alanrichardson
If you bring up Windows/File Explorer and up at the top type %temp% (and hit a return/enter)..  It will take you to your personal temp folder.
Mark Lancaster
alanrichardson
Mark,
This is the error message . . .
<Error applying transforms. Verify that the specified transform paths are valid.
C:\Autodesk\WI\Autodesk Inventor 2020\x64\INV\inventor.mst>
I have the path to the INV folder but I do not have an .mst file.
I'm considering and uninstall followed by an install. As 2020 stands it's driving me up the wall.
Alan
Mark.Lancaster
@alanrichardson
You must've installed using the web installer/install now function.   I don't like the web installer..   You may have to uninstall and reinstall using the full software download method.
Mark Lancaster
