Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Inventor Forum
Update Assembly features to individual parts.
6 REPLIES 6
1157 Views, 6 Replies
I was wondering if there is a way to 'push' features and additions in an assembly to the corresponding parts. I started using a multi-body part and exported to an assembly where I'm looking to further configure and specialize my parts to suit my design and I find it easier to work in an assembly than to try and make every part within a multi-body part so I'm wondering if there was a way to update my parts in the .ipt files from the assembly.
Thank you,
6 REPLIES 6
JDMather
You can edit your parts within the context of the assembly
or
if you are on subscription get the add-in to push assembly features to parts.
This same question was posted here yesterday.
http://forums.autodesk.com/t5/inventor-general-discussion/inventor-2012-adding-holes-to-part-in-whil...
well, I thought that app made it out of Labs to the Apps Exchange, but now I can't find it.
https://apps.exchange.autodesk.com/
in reply to: JDMather
JDMather,
editing parts within an assembly does not seem to include updates in the
original multibody part from which the assembly was generated, only the
stand-alone part files, is that correct?
Cadmanto
Like it has been mentioned, you are best if you like working in the assembly mode to edit the parts in the assembly instead of adding assembly features.
There is no way where you currently are to push the features added in the assembly down to the parts.
Something else you might want to take a look at is derived parts.  Depending on your design intent.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
blair
Look for the "CoolOrange Feature Migrator" : https://apps.exchange.autodesk.com/INVNTOR/en/Detail/Index?id=appstore.exchange.autodesk.com%3afeatu...
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
in reply to: blair
I don't know if the app has disappeared but I was actually having trouble for whatever reason with the coolOrange FeatureManager yesterday.
Oscar
JDMather
@Anonymous wrote:
JDMather,
My impression is that you wanted to add features after the multi-body was pushed out that would only occur in the Derived Components.
If you want to edit the multi-body in context of other parts in an assembly - you will of course, have to add the multi-body file to the assembly.
