As a new user I'd like to know if it is possible to create a sketch and extrude (hole in my example) on an unwrapped surface. I would like that feature to then translate directly to my main design (a rolled cylinder).
Is this option possible in Inventor?
I have attached an example pic.
For this design I have to make multiple holes in the rolled cylinder using angled planes, always at a different location depending on the model. If I could just wrap this sketch around the surface and using either extrude or hole command remove the material in the cylinder it would save me a good bit of time.
Thanks!
