Unlink Excel parameters from part
info8NDVX
info8NDVX
I was hoping to make a part with linked parameters, use this part to create the size i need, save a copy, then make another sized part, save a copy of that and so on.
However when i Save copy as, the copy still have the linked parameters from my Excel file, is there a way to unlink this part?
James_Willo
Right click in the parameters window where it shows the excel file path and choose delete folder.
Any parameters that are used in your design will remain, if they are not used in your part, they will be removed.
James W
Inventor UX Designer
info8NDVX
Fantastic, thank you very much!
branjithkumar
I need to unlink excel sheet from table in inventor Drawing. i did now cannot edit the table.
formobalaji
how to unlink all the folders of parts in an assembly at once, is the any code..
