Inventor Forum
Units command under document settings
10 REPLIES 10
Message 1 of 11
Billduck
759 Views, 10 Replies
Where did they put it in IV 2013?
10 REPLIES 10
Message 2 of 11
blair
in reply to: Billduck
Still in the Documents, you just need to go: Tools>Options>Document Settings>Units.
Delta Tau Chi ΔΤΧ
Message 3 of 11
Billduck
I'm not seeing it. See attached image.
Message 4 of 11
In the drawing environment, click on the 'Manage' tab, then styles editor. From the drop down, show All styles, double click on the standard you wish to use.
If you need to change the standard often, it may be worth editing the drawing template and make that standard a permanent change.
HTH
Message 5 of 11
Billduck
    Sorry I was not clear on my question. I somtimes I have to measure a distance to high accuracy in an ipt or iam. The attached jpg, shows how to change the # of decimal points in an ipt in IV 2012. If you compare the dialog in IV 2013 version, there is no units tab. It is missing.
Message 6 of 11
mrattray
It's there in mine.
Mike (not Matt) Rattray
Message 7 of 11
Billduck
in reply to: mrattray
Well dang! Maybe an Autodesk tech can tell me what's up?
Message 8 of 11
mrattray
What does your 2013 menu look like?
Message 9 of 11
Billduck
See post # 4.
Message 10 of 11
mrattray
Well that's an image of an .idw's document settings. The menus are different for an idw, an ipt, or an iam. Nothing new there.
Message 11 of 11
Billduck
Thanks, My bad.
