Inventor Forum
Inventor Forum
Highlighted
Post 1 of 11
Units command under document settings
302 Views, 10 Replies
05-21-2012 05:28 PM
Where did they put it in IV 2013?
Well that's an image of an .idw's document settings. The menus are different for an idw, an ipt, or an iam. Nothing new there.
Thanks, My bad.
Post 2 of 11
Re: Units command under document settings
05-21-2012 09:02 PM in reply to: Billduck
Still in the Documents, you just need to go: Tools>Options>Document Settings>Units.
IV2017r3 PDSU / Nastran / Nastran In-Cad / Sim Mech 2017
Win 10 iCore7 6700k Skylake 4.0GHz 32Gb ) Radan R9 Fury X, 16.12.2
SpacePilot Pro 10.4.8
Mac Pro 16Gb,Xeon 3.7GHz, dual AMD 700, Boot Camp 6.0, Win10, SpacePilot Pro 10.4.8
MacBook Pro, Parallels 12 / Win 10
Delta Tau Chi ΔΤΧ
Post 3 of 11
05-23-2012 04:35 AM in reply to: Billduck
I'm not seeing it. See attached image.
Post 4 of 11
05-23-2012 07:14 AM in reply to: Billduck
In the drawing environment, click on the 'Manage' tab, then styles editor. From the drop down, show All styles, double click on the standard you wish to use.
If you need to change the standard often, it may be worth editing the drawing template and make that standard a permanent change.
HTH
Regards
Andy M
Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
Post 5 of 11
05-23-2012 07:36 AM in reply to: trumpy81
    Sorry I was not clear on my question. I somtimes I have to measure a distance to high accuracy in an ipt or iam. The attached jpg, shows how to change the # of decimal points in an ipt in IV 2012. If you compare the dialog in IV 2013 version, there is no units tab. It is missing.
Post 6 of 11
05-23-2012 07:39 AM in reply to: Billduck
It's there in mine.
Mike (not Matt) Rattray
Post 7 of 11
05-23-2012 07:40 AM in reply to: mrattray
Well dang! Maybe an Autodesk tech can tell me what's up?
Post 8 of 11
05-23-2012 07:43 AM in reply to: Billduck
What does your 2013 menu look like?
Post 9 of 11
05-23-2012 07:45 AM in reply to: mrattray
See post # 4.
Post 10 of 11
05-23-2012 07:47 AM in reply to: Billduck
Post 11 of 11
05-23-2012 07:53 AM in reply to: mrattray
Thanks, My bad.
Inventor Exchange Apps
