Message 1 of 10
So, I have an STL file for which I'm trying to import, convert to solid using mesh enabler to edit. The problem is that inventor defines the unitless units as inches instead of mm. As an example, this part should be 25mm tall but is instead imported as 25 inches tall, and changing document settings only changes the units, not the scale of the object. This causes problems when 3d printing.
How would I go about choosing what unit Inventor chooses for my file?
Using Inventor 2021 Professional
