Announcements
Unique BOM line and Item Number for multiple instances of the same component
waynehelley
waynehelley
Hi all,
I'm working with the 'Parts Only' Bill of Materials.  The problem I have is that it is critical for multiple instances of the same component to have different item numbers, since the numbering needs to match up the hydraulic circuit drawings
Here a couple examples.  To achieve what we have here, we have had to use balloon overrides and will have to manually add lines in to the Parts List.
Is there a cleaner way to achieve this?  I don't want to go down the road of using table driven or derived parts.
Many thanks,
Wayne
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
Replies (13)
swalton
I am not aware of anything out-of-the box in Inventor.
However this thread seems to be what you need: https://forums.autodesk.com/t5/inventor-forum/inventor-understanding/m-p/6556138/highlight/true#M612...
Steve Walton
Inventor 2025
Vault Professional 2025
johnsonshiue
Hi! This is an interesting request. I have heard it before. Internally, we call it "occurrence based BOM attributes." The schematic you are looking for is not yet supported in Inventor BOM and PartsList. Youl will need to use sketch symbol to do that. Inventor BOM and Partslist is meant to create a purchase list or inventory list so that users can order parts based on the list.
Many thanks!
Software Test Engineer
kelly.young
Autodesk Support
Autodesk Support
Hello @waynehelley I am checking back to see if any of the replies helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Select the Accept as Solution button if a post or posts solves your issue or answers your question.
pasi.annila
Hi Wayne,
I would also need this.
Please ad this as a wish on ideas section.
BR,
Pasi
Marcin.Szklarek
I am just going through electronic assembly with multiple instances of the same parts. I originaly thought that instances will allow that, why else would you have them if they are shown as separate in BOM. It is at the moment like attaching another bit to part number. Instances are more likely to be used to show exact location combined with assembly  drawing ( no ballons).
Kind of dissapointed but I hope this could be implemented. Merging a part number and showing all instances in one box wit coma or back slash separator( i.e. r3,r10,r30).
The way it is now BOM will be unnecessarily long.
pasi.annila
Little more specks from my point of view.
About the numbering and separator. The dot "." is already used in multilevel BOM so there should be some other separator. I think it should be user select-able.
Also it should have option to select which part(s) in BOM behave like this (not all). You might have parts like screws in the same assembly with parts like photocells - only photocells should have asked behavior (it actually depends on item not BOM, weather to use it or not).
Marcin.Szklarek
That is done already,I think. If you do not set your attribute to instance it will not show up. You could also choose different instances attributes ( bolt instance, capacitor instance) and they will not overlap.
johan.degreef
I know this is a very old topic, but doesn't "Instance iproperties" help in this case?
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
johnsonshiue
Hi Folks,
Yes, Johan is right. This should be taken care by Instance Properties in 2022. Instances of the same component at the same level can have different values of the same property. If it is not working, please share the example that exhibits the behavior.
Many thanks!
Marcin.Szklarek
What you have shown is exactly the issue. On the BOM if you merge it shows VARIABLE. It does not show instances.
It is much better if you have a look up to all instances. Just like BOMS of PCBs. If inventor is supposed to work with EAGLE PCB software  then that kind of instances in BOM has to be taken in to account. It is a step forward but the result which is BOM is not much helpful.
johnsonshiue
Hi Marcin,
On 2022, the row merge option includes a secondary option allowing different instance to be listed as a separate row. It should work unless I misunderstood the request. Please share an example that you are working on. We can easily tell if Instance Properties helps fulfill your request.
Many thanks!
Marcin.Szklarek
Hi!
Yes, that is correct and that is what actually is a problem. Imagine you have an assembly with 30 types of resistor and 5-6 instnces of each. If you merge it says Varies if you choose not to merge it it will show each instance separate. That is manny lines in BOM.  My expected behaviour would be to show all instances in window  next to one part.
That way you have quantity and instances grouped in one point and no need for multiple BOMs ( purchase and placement instances).
It is a great feature, but it would be nice to take it further.
johnsonshiue
Hi Marcin,
Many thanks for clarifying! I get the point now. It is about the ability to show the variance, instead of using "Various."
Assembly BOM table has been positioned as the single source of truth. There are very few customization workflows allowed.
On the other hand, PartsList is more customizable. Maybe you could use PartsList to show the desirable result by enabling Grouping.
Thanks again!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
