Unique Angle in drawing
Hi All,
I have a situation where I a have a 'sort of' A-Frame with a series of brackets off the sides, which are at differing angles (see attached below)and needs individual angles dimensiones. If I project a view to the right, then all my brackets naturally sit at an angle to the view plane. I tried using Auciliary view to project a angled view, however it came out at some funcky angle on my drawing. Is there a way to get a view which is perpendicular to the angle of my A-Frame, but is however neatly to the right and in line with my original view?
Thanks in advance!
Jakob
PaulMunford
You will need the 'rotate view' tool, to rotate your projected view to your preferred orientation.
Autodesk Marketing Manager D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
MechMachineMan
In 2016 When you place a view or edit one (that doesn't have section views) a view cube should appear to the top and right of it. Click the dropdown arrow there and select "Custom View Orientation". Then use Look Up on the surface you want to be perpindicular to. Finsh the Custom View and you are good to go!
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thanks Paul, that did the charm.
Justin,
Unfortunately not running 2016, but 2015. Sounds very similar to the view cube function in Solidworks though.
Cheers.
