Unhandled Exception upon Startup
Message 1 of 25
I am running Windows 7 x64
Inventor 2015
Whenever the program is started I get the loading splash page then it fails with the error window.  If I go into Programs and do a repair, and start the program again I get the EULA then the same thing happens again.
The error doesn't seem to give me a lot of information.  I have probably 100 machines at our district and we have steadily been getting more reports of this issue.
Replies (24)
Message 2 of 25
Would really love a response to this!
Message 3 of 25
Mark.Lancaster
What happens if you right mouse click on the Inventor icon and run as admin?
Can you provide more details about your machines?  Ram, free disk space, video card and its driver version?
Mark Lancaster
Message 4 of 25
Same thing.
Even if I log onto local admin, a domain admin or a non-admin.  Same issue each time.
I just went into the "create and modify deployment" tool and saw there was a service pack update.  I am going to push this out and see if we can get any changes.
Message 5 of 25
Mark.Lancaster
Can you provide me with details of your machine (see my other posting)
Mark Lancaster
Message 6 of 25
Generally the computers have an i3 with 4 gB of RAM.  The kids are using the computers now so I can't get all the specifics for you now.
Message 7 of 25
Mark.Lancaster
Intel i3 does not meet the min requirements (http://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticl...
Mark Lancaster
Message 8 of 25
I know but we are a school district with not a lot of money so we have to work with what we have.  It works on some machines though, its just not starting on some of them others it works perfectly.
Message 9 of 25
Mark.Lancaster
What is the actual message you are getting.   Please take a screen shot of it and attach here.
Mark Lancaster
Message 10 of 25
Here you go.  One is the initial box and the other is after I press the view error details button.
Message 11 of 25
Mark.Lancaster
I need the dumpuserinfo.xml file that is located in C:\user\<username>\appdata\local\temp folder.  This file only appears if the dialog shown in the 2nd image is still present on the machine.
However this file contains your serial #.  So if you do not want to share this info with the entire community please send me a private message and I will tell you how to get this file to me.
Mark Lancaster
Message 12 of 25
Sent.
Message 13 of 25
Reinstalled Inventor with SP1/2 and updates and problem persists on multiple profiles on the machine.
Previous version was completely removed before new install.
Message 14 of 25
ChrisMitchell01
Travis,
What sort of graphics hardware do you have installed ? If you have an on-board Intel GPU, please ensure to update that graphics driver, or disable the Intel GPU & use the other main graphics card, asssuming you have one installed.
I don't see any crash reports in our system with your email address. Please ensure to add your email address & send the CER reports in.
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 15 of 25
I just submitted the error report to you.
This machine was reimaged today fresh.  Its also had Inventor put on it today fresh which I added SP1, 2 and update 1 and 2 for SP 2.
All updates and SPs were installed during the deployment.
As soon as I start I get the EULA, then it fails.  This time I submitted the error.
Message 16 of 25
pdxmcad
Travis,
In order to locate the crash report we need to know what email address you entered into the report.
Mike.D
Developer, Autodesk Inventor
Message 17 of 25
travis.nelson@salinasuhsd.org
Message 18 of 25
pdxmcad
Travis,
I don't see any reports in the system assigned to that email.
In your %TEMP% folder, do you have a dumpdata.zip with a time stamp which corresponds to your last attempt to launch the product?  If so, please email it to me using mike.dickason@autodesk.com.
Mike.D
Message 19 of 25
This has been sent to your email.
Message 20 of 25
pdxmcad
Travis,
Based on the dumpdata.zip you emailed me, I see two immediate problems.   The crash report indicates you have the Microsoft .NET Framework 4.0 installed, but the requirements for Inventor 2015 are to have .NET Framework 4.5 SP1.
The second issue is the Intel video driver you are using on the machine is over 4 years old.   You need to download the latest Intel video drivers for your hardware.
Mike.D
