Hi all,
First of all I am a very basic user to Inventor. I manage to do my normal work, but am very new to Sheetmetal part of Inventor. So I need help please, if you would be so kind.
I downloaded a STP file from GrabCad of a toolbox/cart. I would like to modify (make it a bit bigger, maybe two side by side configuration). But it seems that the cart are made of solid bodies? But then again, when I zoom in on the bends, it looks like sheetmetal?
I opened one of the drawers to edit. Converted it to Sheetmetal and set the default to 1mm. However, I can not unfold it. I even created a Flat Pattern (but nothing happened. I mean, it didn't fold flat). Clicked on "Go to Folded part" and tried to use the unfold option. But it doesn't allow me to select reference A. All the "fold lines" are marked in yellow. I have searched the internet as best I can for an answer, but came up empty handed.
I would appreciate (at least a nudge in the right direction) any help. I have attached the Assembly for review?
Thank you in advance for any help.
Théo.
AutoDesk Inventor Noob
