Inventor Forum
Undo Command
8 REPLIES 8
Message 1 of 9
ntwiggar
670 Views, 8 Replies
Undo Command
Why does the Undo command let me undo steps from a previous file? If I'm working in an assembly, then switch to a part file (leaving the assy open), my next undo command refers to the last command in the file in the previous window (or last open file), not the last command in the curently open window. Is there a setting or switch that I'm unaware of?
8 REPLIES 8
Message 2 of 9
in reply to: ntwiggar
It's one of those feature you'll come to love in Inv 😞
Unfortunately Inv doesn't create separate UNDO files, nor does it create large enough UNDO files
I'm afraid I can't suggest any workaround or switch or setting or anything that might help, other than putting a Wish into
http://www.augi.com/inventor/default.asp
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be
as mad as what passes for ordinary living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
http://support.microsoft.com/default.aspx/kb/555375
wrote in message news:5863580@discussion.autodesk.com...
Message 3 of 9
JDMather
How big do you need?
Message 4 of 9
More than 1000 MB
Pentium D950 3.40 GHz
2.0Gb RAM, 4Gb page, /3Gb & /PAE
Win X/P sp2 & I.E.7 [all hotfixes]
AIS2008sp2, Build: 320
ATI Radeon X800
(Bios 11x-A47466-103)
(Drv. 8.383.0.0)(Config 11Jun07)
D3D Version 6.14.10.0503
OGL Version 6.14.10.6479
2D 6.14.10.6698
Duncan
Message 5 of 9
billco-mfg
Did you try to apply that setting? 1000MB is the max it will take.
Message 6 of 9
JDMather
Oops, didn't try apply.
Message 7 of 9
To have 1Gb per open file would be more useful or 10Gb overall.
Duncan
Message 8 of 9
Edit the registry, maybe? At your own risk!
With iTweak, you can edit the # of Undo levels.
http://www.mcadforums.com/forums/viewtopic.php?t=2711
Mike
"Duncan Anderson"
wrote in message news:5864371@discussion.autodesk.com...
Duncan
Message 9 of 9
ntwiggar
Thanks for the reply. Been using IV for a number of years now, but never noticed that limitation before. I think I was in the middle of editing a sketch on a part, switched to the assembly, moved some contraints around and measured some distance. Then went back to the open sketch and realized I didn't need to do what I had just done on the sketch and tried to undo...but it wanted to undo the contraints I just placed on the assy, not the trimming of the line I edited before that. Will have to keep that in mind...
