Unable to switch off planes and axis
tomVB9DQ
tomVB9DQ
I opened an assembly and all of a sudden all the parts have planes and axis turned on (see picture). How do I turn these off? I have tried "uncheck all workfeatures". Many thanks.
Gabriel_Watson
Are those COGs? Make sure they are switched OFF here:
EDIT: depending on your version you may need updates (see link below)
https://forums.autodesk.com/t5/inventor-forum/turn-off-center-of-gravity-problem/m-p/7825303#M685068
JDMather
What version of Inventor are you using (including Update number)?
If toggling the Center of Gravity visibility doesn't work -
This issue sometimes happens in older versions of Inventor when a part is corrupt.
Can you Attach the assembly here?
Also go to the Manage Tab and click Rebuild All.
tomVB9DQ
Thanks for the reply, below is the version and I have attached the assembly
JDMather
@tomVB9DQ
I am not seeing the issue on my machine with your files.
If you reboot the computer does the problem persist?
tomVB9DQ
Thank you, it was the COG planes that for some reason showed up and was not possible to turn off. Rebooted and they disappeared.
