I am new to Invetor; I mostly use AutoCAD or Solidworks, and I have a fairly unique piece to dimension (Shown Below).
I am having trouble with step 6 of Slicing Operation Steps as per Autodesk Inventor Help Topics:
Create a Slice operation defined by sketch geometry
- Select an existing view for the Source view.
- On the ribbon, click Place Views tab
Sketch panel
Create Sketch to open a drawing sketch associated with the view. - Create sketch geometry to define an open slice sketch, and then exit the sketch environment.
Modify panel
Slice . - Select another view for the Target view. The Slice dialog box is displayed.
- Select the previously defined Slice sketch as the cut sketch.
Optional: Check Slice All parts to override Browser component settings and slice all parts in the view, according to the Slice sketch geometry. Components that are not crossed by the Slice Line do not participate in the Slice operation.
- Click OK to perform the Slice operation.
Whenever I get to step 6, the option to select the slice sketch is not available. When I hover the mouse over the Sketch, nothing happens. PLEASE HELP.
Thank you for reading!
P.S.
When you create a 2D drawing, you will need to go to the 3D model and break the link with HEAD,machined, A590.ipt first.
