Good day
While I was busy saving and checking my model back into vault my electricity went out. When trying to open the model now it needs to resolve some links(which it is unable to do). When I open the model and try and replace the model with it self or just open the model I get this error?
How do I go About fixing this?
Solved by CCarreiras. Go to Solution.
Hi!
Most probably, the file is corrupt.
In the working folder, search in "OldVersions" folder and check if you have a copy(backup of the file.
If it exists, copy the backup file to the main folder, save copy as and rename the file and carry on.
Tahnx @CCarreiras
Yes so, I had to go through all the affected parts and had to compare with c drive and old versions and vault.
Quite a tedious exercise.
I got them all resolved, but my model is super slow after this
