Unable to open parasolid in Inventor 2023
chris_copland
Observer Observer
chris_copland
Observer
Observer
When I try yo open a Parasolid file, inventor returns error "The file is a newer version than Inventor can read. Install latest updates and try again." All available updates are loaded but still unable to open.
TheCADWhisperer
Can you Attach the parasolid file here?
chris_copland
Observer
Observer
Using Inventor 2023.2 but unfortunately I am unable to share the Parasolid due to NDA
CCarreiras
Hi!
Probably the Parasolid file is coming from the most recent version. if it is the case, every year  Autodesk team has to work to update the translators to open those new versions.
When translators are ready, they launch the service packs to able that... probably in update 2023.3
Meanwhile, you can ask somebody to translate the parasolid file as a step, then you can open.
CCarreiras
johnsonshiue
Hi Chris,
You will need to install 2023.3, when it becomes available. It will enable translation support for other major CAD vendors' file formats.
Many thanks!
Software Test Engineer
