Inventor Forum
Unable to Offset Lines
4 REPLIES 4
745 Views, 4 Replies
I get this following error after offsetting the line and adding a dimension.
" [WARNING] Adding this dimension will over-constrain the sketch. Choose Accept to create a Driven Dimension. [r:\Application\Sc\Request\DimensionReq.cpp, line 237]"
By removing the "Constrain offset" created line will hide behind reference lines and unable to offset.
help is appreciated. IV11.
Peter
4 REPLIES 4
johnsonshiue
Could you send the part to me or post it here, so I can take a look?
Thanks!
Johnson Shiue
johnson.shiue@autodesk.com
Software Test Engineer
Look at Corrupt part post. It is a same problem.
Since than I have abandoned the idea of folding plate in one part.
I am creating flat plate and derive in to sheet metal to be folded. this seems to fix the offset problem, but now Ordinate dimension will not pick some edges. very frustrating.
Attached are all files needed to analyze.
Peter
Solved problem with the dimensions. Overlapping Views.
Is there a easy to bring a view on top?
Peter
Your description of the problem is not clear. Are you talking about the CAM
Profile sketch in the -flat.ipt?
If so, then you can offset the Profile Sketch by trimming the line shown in
the attached image before you offset.
Why is this sketch larger than the outer limits of the part? I would have
used coincident constraints.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
wrote in message news:5948362@discussion.autodesk.com...
dimension.
Peter
