Unable to install Inventor 2021, error 1603
Hi everyone,
I am unable to install inventor 2021, neither from autodesk desktop, nor from the browser offline installer. I always get the error 1603. I have tried all online solutions I could find on the topic, including:
-multiple clean uninstalls, following this guide: https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall, including reboots inbetween
-removing all remaining registry entries, following: https://knowledge.autodesk.com/customer-service/download-install/remove-products/remove-windows-prod...
-Installing the newest license manager update, following:https://knowledge.autodesk.com/search-result/caas/downloads/content/autodesk-licensing-service-downl...
I have also tried different combinations of the above mentioned methods, including deleting all autodesk files following other knowledge guides, not listed here, but to no success. I am at a loss and would appreciate any help.
The logfile says (some parts in German):
LicensingCustomAction.licIsSvcUpgraded [I] [13:49:01:002]: Running helper with params: "C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\10.2.0.4231\helper\AdskLicensingInstHelper.exe" upgrade isUpgraded
LicensingCustomAction.licIsSvcUpgraded [I] [13:50:07:000]: process exit code: 106
LicensingCustomAction.licIsSvcUpgraded [E] [13:50:07:001]: exit code: 0, output: Starting Windows service "Autodesk Desktop Licensing Service" failed: Der Dienst antwortete nicht rechtzeitig auf die Start- oder Steuerungsanforderung.
. Action ended Return value 3
LicensingCustomAction.licIsSvcUpgraded [E] [13:50:07:001]: Failed to upgrade: Starting Windows service "Autodesk Desktop Licensing Service" failed: Der Dienst antwortete nicht rechtzeitig auf die Start- oder Steuerungsanforderung.
CustomAction licIsSvcUpgraded.8B858D99_2C63_4281_AE43_6782314CCC1B returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
Cheers
