Unable to change precision for a hole diameter when tolerancing.
Trying to use the "Tolerance Feature" to define a hole pattern but it will not allow me to select a precision:
When using "Tolerance Feature" for other features, such as the width or the outside diameter, there is a dropdown that allows you to change the precision, but this option does not exist when Tolerancing a hole feature:
The hole is defined with a 3-digit dimension and is set to 3-digit precision, but the annotation always comes in at 2-digits for some reason:
If I use "Dimension" or "Hole/Thread Note" the option is there to change the precision:
The problem is that when using "Dimension" or "Hole/Thread Note" you can't add a Position Tolerance Feature Control Frame, that is only an option when using "Tolerance Feature".
How can annotate this hole to have a 3-digit dimension but also a Feature Control Frame?
