unable to bridge between cilinders in freeform enviroment in inventor 2020
Message 1 of 17
When I try to make a bridge between two cylinders (see picture 1) I get an error that says it's not possible. I know that in previous versions of inventor it was possible to do this in this way.
If I select 3 or the 4 faces on one side or two extra on the side then it will be accepted
223344
this is the other side of picture 3 and is exactly what I want on both sides
55
Replies (16)
Message 2 of 17
johnsonshiue
Hi! The behavior does not look right to me. I just try a similar case on the coming 2020.1 update. It seems to work. Could you retry it on 2020.1 update when it becomes available? If it still fails, please share the file here. There might be geometry specific issue.
Many thanks!
Software Test Engineer
Message 3 of 17
Just wanted to comment that I am having the EXACT same problem, and this is even in the tutorial (Freeform 1) where everything is set up for you.  In task #3 in the tutorial, it asks you to bridge two cylinder sections between 4 faces of each cylinder.  Like the OP, I only get a preview when an odd # of faces is selected on the second side, so when I ultimately have 4 selected on each side, it gives me the 'Freeform Bridge failed' message.  All the parameters in the 'bridge' function are as specified in the tutorial.
Message 4 of 17
johnsonshiue
Hi! Have you installed 2020.1 update?
Many thanks!
Message 5 of 17
Yes I think so, installed an update a few days ago. Desktop client says
there's no more updates available
Message 6 of 17
johnsonshiue
Hi! Please go to Help -> About and check the exact build you are running. Does it say 2020.1?
Please attach the part file here so forum experts can take a look.
Many thanks!
Message 7 of 17
It says Version: 7.0.16.29
Message 8 of 17
JDMather
Inventor 2020.1 Update.pnghttps://manage.autodesk.com/home/
Message 9 of 17
I can't for the life of me figure out how to get to that page.  Clicking help from inside Inventor takes you to web help, clicking 'help' on Autodesk.com gets me nowhere either.  What I posted earlier I found by clicking the 'help' in the 'Autodesk desktop app.'
Can you walk me through the exact steps to get to that screen please.
Message 10 of 17
JDMather
Black down arrow next to ? mark.
Message 11 of 17
Yeah I've clicked every black arrow available... I don't even know if you're talking about within Inventor, within the desktop app, or within web help, but since you aren't being very specific I guess I'll just post a photo of all three and their lack of what you're describing.
Message 12 of 17
JDMather
Open an Inventor File.  See the image that started this discussion (upper right corner of the image).
Message 13 of 17
Well looks like now we are getting somewhere, it turns out that icon is hidden in inventor because I'm using a trial version.  If you looked at the photos I already posted, you can see what I'm talking about...
It says I have version 2020.0.1, which is not 2020.1.  How do I update if the desktop client says there areno updates available?
Message 14 of 17
johnsonshiue
Hi! Please log on to manage.autodesk.com and find 2020.1 update.
Many thanks!
Message 15 of 17
It says there are no updates available!!  Is this somehow related to the fact that I'm using the trial?  I haven't been able to work on this model for 2 days now and I really would like to make sure the program is stable and working properly before the trial runs out.  So far this isn't off to a good start.
Message 16 of 17
johnsonshiue
Hi! Yes, it is true that trial license does not have access to updates.
Many thanks!
Message 17 of 17
Wow
