The DWG in question has a view of an IPN of an ASY. Some components simply will not accept balloons in the view of the IPN. When placing a view of the IAM, all components are able to be ballooned. All components in question have a BOM structure of normal. When those same components are placed into a new assembly, a new IPN is created, and a new drawing is created with those same views, the issue does not reoccur.
The components in question MAY have been placed into the ASY via a Right-Click>Component>Replace at some point in its history. Edit: I have done a Component>Replace in my new, recreated assembly and that did not cause the same failure.
Some troubleshooting has been performed, but no solution has been found. See linked screencast for details: https://autode.sk/3ySupFX
Solved by johnsonshiue. Go to Solution.
Hi! I believe this is a known issue (reported as INVGEN-54019). I checked the defect status. It is currently targeting 2022.2 update.
Many thanks!
OK Johnson, thanks. I hope the issue gets rectified soon. On this particular assembly since it is not complicated there wasn't too much pain caused by the issue. On a more complex assembly though it would be frustrating to need to create the whole IPN over again.
