Un-grounding frame in assembly
khop1984
khop1984
Is there a way to move a frame, made with frame generator, in an assembly, or do you have to remove all the frame and constrain the sketch?
johnsonshiue
Hi! The quickest way is to right-click on the Frame subassembly -> iProperties -> Occurrence -> uncheck "Grounded." Then use Free Move command to move the Frame subassembly.
Another workflow is to place the top-level assembly hosting the Frame sub into another assembly. Then the entire Frame can move as a whole.
Many thanks!
Software Test Engineer
