ucs icon?
EngineeringMNAJ7
ucs icon?
EngineeringMNAJ7
How can i turn off the ucs, or whatever these things are?
Replies (7)
inventorprotools
Observer
Observer
Tray to press  Alt + ¡  or  Alt + ]   to hide all planes.
See the main shortcuts on https://inventorprotools.com/blog/post/3-best-autodesk-inventor-tips-and-tricks-shortcuts
EngineeringMNAJ7
thank you for the suggestion, did seam to work
JDMather
COG (center of gravity) visibility.
JonathanKruger
I believe the Alt + option is going to be a temporary fix and they will come back on the next time you open the same assembly, unless you create a custom view rep hiding all them.
The image you posted reminds me of the below issue. Maybe see if the workflow fixes it?
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Inven...
If this solves your issue please mark this posting with the "ACCEPT SOLUTION".
If you like something that was said or if it was helpful, Likes are appreciated. Thanks!
EngineeringMNAJ7
Thank you for your help still working on a solution.
EngineeringMNAJ7
Thank you for the help, still working on a solution.
johnsonshiue
Hi! Go to View -> Object Visibility -> turn off certain objects accordingly. If this does not work, it could be a scene corruption. Go to Manage -> Rebuild All -> Save -> Close and Reopen.
Many thanks!
Software Test Engineer
Type a product name
