- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a problem with the standard Two Light Environment.
I find it, and many people with me, too dark.
When you take the brightest white material, for example plastic "POM White" it displays grey.
I want to change Brightness or ambience to make it less dark. (for example, change Ambience from 40 to 80)
When I make a shaded drawing view, the colors are still with ambience 40
Is it possible to make shaded view look the same as the updated lighting style?
Also for example content center items 'Hex Nut Steel Black passivated' in the display appearance I turned on Depth Dimming to see more contrast when using 'Shaded with edges'. I cant get this visible on drawing.
Any thoughts and ideas are welcome, thanks in advance,
Arnold
