Tweak a component in the x and y direction at the same time.
collinsjamesQVZK7
collinsjamesQVZK7
Is there any way to tweak a component in the X and Y direction at the same time.  I'm doing an animation and making two movements makes it look jerky.
johnsonshiue
Hi! I guess you will need to rotate the triad axis around Z-axis 45 deg. Then drag X or Y.
Many thanks!
Software Test Engineer
collinsjamesQVZK7
Thanks.  Since this is an animation for an instruction video, i decided to use 3DS Max for the animation.  To me there was nothing wrong with the sidestep that I had,
but Sales wants pretty not effective.
hollypapp65
You can move parts by driving constrains.  Check out Studio in Inventor.
collinsjamesQVZK7
Thank you, I was aware of that.
SBix26
Create two separate tweaks as desired, then drag the second one in the timeline to be coincident with the first one.  Two (or more) tweaks can occur simultaneously.
Sam B
Inventor Pro 2026.1.1 | Windows 11 Home 24H2
collinsjamesQVZK7
Thank you.  I'll try that and keep it for future reference.  I used 3DS Max for the animation I needed.
