Turning a part into an assembly
drawingsCHR7R
drawingsCHR7R
Hi Guys,
So i was busy with an ipt. file and I completed it, I now want to take the gussets in the ipt file and separate it from the flange so that it is two individual ipt files and one assembly, is there a way to do such a thing?
Attached is the part file.
Thanks.
aurel_e
I can't open your model right now, but if as I suspect, it is a multibody, you ca use the make components tool as explained in this video
https://www.youtube.com/watch?v=iDRotf2Is2g
drawingsCHR7R
Thank you, that worked perfectly.
