Tube and Pipe style problem
mjc_design
mjc_design
IV2017 - I've set the style for a pipe run to ISO 4065, but for some reason every time I use "populate route" its puts a load of ASME parts in place. I've closed the assembly and re-opened it, and its still doing the same thing.
I'm at a loss as to how to overcome this - any ideas?
gcooper79
When do you set the style to ISO 4065?  when you are in the route environment or when you are in the run environment? For the route to inherit the properties of the style, the style has to be set in the route environment.
Graeme
