Message 1 of 37
Tube and pipe - adding flange
03:50 AM
Hi.
I've created a pipe style that's a mixture of welded and flanged pipework. I've started the route from a tank outlet flange (the flange is modelled as part of the tank). Currently the model shows the pipework welded to the tank outlet flange, but obviously I want to add a flange to the end of the pipework to allow it to connect to the tank outlet.
What's the best way to do this?
I have found the "Edit Fitting Connections" command, which shows the end connection to the tank (a separate part in the assembly) but the Engagement is shown as "User Defined" and greyed out so I can't change it (see screenshot). Is there some way to change it to specify a flange?
Many thanks
