Tube & Pipe slow performance
joeldavide
joeldavide
We are experiencing an issue with Tube & Pipe overall performance.
I have attached a Screencast of that issue.
This project was working just fine some weeks ago, but now even with almost everything suppressed it just takes forever to do anything inside tube and pipe module (you can see it takes 1 min to do a connect fitting). Other projects work just fine (although we had this issue from time to time).
Outside this module, all works with normal speed.
Computer Specs:
Intel I9 - 9900
32 GB RAM
Nvidia Quadro RTX4000
Best Regards,
Joel
johnsonshiue
Hi Joel,
It is hard to tell where the exact problem is by looking at a video. If possible, please share the files here or directly with me [email protected]. I would like to understand the performance issue better.
In the meantime, you may try to delete or suppress some components and see if there is a culprit.
Many thanks!
Software Test Engineer
joeldavide
Hello Johnson,
What's the format of the files i should share with you?
Best regards
johnsonshiue
Hi Joel,
Please share the Inventor files in zip. If less than 50 MB, you can email me directly [email protected]. If larger than that, please share it on a cloud drive of your choice.
Many thanks!
