Tube & Pipe Issues (Crash on new route & Presentations loosing tweaks applied)
I have a couple of issues with Tube and pipe, which I use a lot.
The first is that once I have created one run and go to create a 2nd run (say a different pipe size), Inventor will crash out. My current work around is to save after every run so I don't lose much, but it's annoying. My work flow is to have my plant GA (surface treatment process line) assembled into an empty assy and then place and constrain fittings, valves, etc, where I want to route the pipework. I then ground everything and suppress constraints before deleting out the main GA - leaving just my fittings in the right places. I then route between my fittings with different runs to allow me to use the same run multiple times if it is a repeating series. I then convert all my auto-routes to sketches and finally populate.
The second is far more annoying. After creating my pipework assy I create an exploded view and drawing for our workforce to work from, and also for our customer manuals and info for the future.
The issue I have is that I can tweak the fittings and pipes to how I want them, save the file, create a drawing and BOM and get everything how I want it, then randomly when I re-open the drawing or presentation, or just switch between the open files within Inventor, the pipes will lose the tweaks applied to them and all revert back to their original position (the fittings are all fine). Nothing I have found will get it to remember the tweaks applied - it's almost like it sees the pipes as different parts all of a sudden. These are large assemblies with over 100 lengths of pipe, and all the fittings, so it isn't a small task to then try to get the pipes back to where I wanted them - and I've then had the same happen again (queue computer nearly going out of the window!!).
Any ideas on either of them?
I'm on 2019 Prof, with the latest updates installed (but I've had it before as well, maybe even a couple of time on my last version, which was 2016).
Phil
