Inventor Forum
Tube & pipe always dirty after rebuild all
3 REPLIES 3
awatt
372 Views, 3 Replies
Using inventor 2020 with Vault pro 2020 add-in.
I have an assembly with a single tube & pipe run, and it ALWAYS is flagged as dirty after a 'rebuild all'.
I've checked everything out of the vault, so I have read-write access. But the vault tab in the browser will always put an asterisk on the top 3 levels of t&p.
Any ideas what I should be looking for?
- The components themselves are up-to-date
- No ilogic routines or triggers are to blame.
Labels (2)
3 REPLIES 3
johnsonshiue
in reply to: awatt
Hi! This sounds like a corruption to me. There could be a way to purge the corruption but I am not 100% sure without seeing the files. If possible, please share the files.
Many thanks!
Software Test Engineer
awatt
in reply to: johnsonshiue
Here it is.  Have fun.
johnsonshiue
in reply to: awatt
Hi! Many thanks for sharing the files! I think this is sort of a limitation. You may be able to reproduce the same behavior with any adaptive components. When you do Rebuild All, the entire adaptive chain will need to be updated and dirtied to ensure they are in the right place.
Thanks again!
Technology Administrators
