Inventor Forum
Trying to model a garter spring
16 REPLIES 16
Message 1 of 17
edarlak
991 Views, 16 Replies
Trying to follow the method shown in this video: https://www.youtube.com/watch?v=ihM4uLzxeI0&t=253s to create a garter spring.
I get as far as adding twist to the sweep but Inventor is giving me a self intersection error.  Wondering where I'm going wrong.  File is attached.
16 REPLIES 16
Message 2 of 17
JDMather
in reply to: edarlak
I don't see the line sketch in the file that you Attached for the Sweep?
Oops, now I see it.
Works fine for me using your file.
What angle are you using for the Twist?
Message 3 of 17
edarlak
in reply to: JDMather
Yeah, I was fudging the angle.  Supposed to be 33,120 deg
I might model the spring in a more simplified fashion though, as the model graphics LOD always seems to be stuck in "chunk mode".
Message 4 of 17
johnsonshiue
Hi! I see the failure now. It seems to be related to the diameter. It should not fail. 33120 should be doable. I am able to make it work if I change the diameter to 1.00 though.
Many thanks!
Software Test Engineer
Message 5 of 17
edarlak
in reply to: johnsonshiue
See attached image.  I was able to model the spring to the dimensions I needed, but graphically, the spring looks terrible...  How do I solve this?
Message 6 of 17
johnsonshiue
Hi! This is a geometry-specific bug in faceting, meaning the graphical representation is messed up. I don't think you can fix it without changing geometry or fixing the bug in Inventor.
Many thanks!
Message 7 of 17
edarlak
So, if this is a known bug in Inventor, when will it be fixed?  A lot of our tooling assemblies use garter springs, would be ideal to model them realistically as opposed to faking them with a hollow toroid.
Message 8 of 17
JDMather
Attach your *.ipt file here.
There are several ways to model this geometry - including using an Equation Curve.
Message 9 of 17
edarlak
File is already attached above, you've looked at it.
Message 10 of 17
JDMather
1. The ipt file you attached above is not complete.
2. The ipt file you attached above is not the most efficient technique.
3. The ipt file you attached above is not the same as the image you attached in response #5.
Message 11 of 17
edarlak
Hmm, pretty it's is the same file, but I will attach again...
Message 12 of 17
JDMather
Pretty?
Message 13 of 17
JDMather
I realized that I made a mistake and will post second example when I get a chance.
Message 14 of 17
JDMather
This example matches the same parameters as your file.
Turn on your sound...
Message 15 of 17
JDMather
Bump.
Eight days and counting.  I would have expected more questions on how to model the geometry.
Message 16 of 17
edarlak
I watched both your videos but I didn't see a file attachment.  I'm definitely interested in how you modeled this spring.
Message 17 of 17
JDMather
