TRYING TO CUT INTO CURVED SURFACE
So, I projected a 2D sketch onto this curved surface, now I'd like to make cutouts on it.
This guy does it, but the video is in Vietnamese (I think).
https://www.youtube.com/watch?v=3Zkswy4XlR8&nohtml5=False
Anyone know how to do it? Part attached as well.
undefined
Replies (11)
JDMather
I would probably do it differently - but using what you supplied....
so what's the better way?
PaulMunford
Use the trim surface command.
Customer Adoption Specialist: Autodesk Informed Design
Help | Learn | Forum | Blog | Ideas | Sample content | Linkedin
I can't get "THICKNESS" to work.  If I tell is 2mm, it works.
undefined
Every time I try that command I get this message.  What am I doing wrong?  BTW, I have your book on order.. shipping from Botswana apparently (taking a long time).
undefined
JDMather
undefined
You have multiple issues in this image.
 Assuming Thickness = 1mm
and
assuming implied multiplication was permitted in Inventor equations.
1. You would have Thickness*1mm= 1mm*1mm=1mm^2, which, of course, does not make sense as a valid parameter for a thickness.
2. If you had Thickness mm you would still have invalid units as the units are already in the variable definition.
Write it out by hand on pencil and paper and you will see.
I don't see the equation this is being plugged into.  Where is that?
I was trying to duplicate what you did.  You part has "thickness".  I found "thickness" from a drop down of parameters, which I assume is where you got it, then it changed itself to add the 1mm on the end.
couldn't you also... (see attached)
Thanks, that's a cool way to do it.  It seems to get "thickness" which your feature had as well, I need to delete off the "=1mm" manually in the dialog box.  I appreciate the help!
Yeah since "Thickness" is the name of an existing parameter, it automatically has the value of 1mm carried with it. You can do that, however, the first time you enter a dimension or input in a feature to rename that parameter on creation. You do need to have Edit Dimension on Creation checked in your application options though. But that allows you to give a parameter a unique name (for referencing later) as you're creating your model instead of renaming or going off some "d#" reference. In other words, create new dimension, in edit prompt type "Length = 36" then when placing a dimension later on, you can simply type in "Length" if you want for that dim to always match the parameter named "Length"... or "Length*2" if you want it to be doubled and so on.
Have a good one.
Thanks for the tips.  I have yet to get into any parameter driven stuff or ilogic, but that's an easy place to start, I will try it out.  Thanks for the help!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
