Trying to combine instance properties in the part list
Jean-Charles.Marin
Observer Observer
Jean-Charles.Marin
Observer
Observer
When using an instance property in the bill of materials, it's either I have one merged line of an item with "Varies" under that column or I can uncheck "Merge instance rows" and have all instance on multiples lines.
Is it possible to combine instance properties one after the other on one line with a separator?
Below a picture with an example of what I would like to achieve.
James_Willo
No this is not possible sorry. If it's merged and the information is different it will always show *varies.*
This follows the BOM rules, so if you turn off merging of instance props, you can see them as separate lines.
James W
Inventor UX Designer
Jean-Charles.Marin
Observer
Observer
Yes it works yes but I find it lengthen the part list.
Thank you.
