Troubleshooting Flat Pattern Sheet Metal Fold Tool breaking holes punches
- Mute
- Permalink
- Report
In Sheet Metal, I have a folded piece of metal angled for a helical curve (spiral) with holes cut / punched throughout it.
- I used the fold tool at the diameter I needed.
- Then I generated a Flat Pattern for my .idw and then inside the flat pattern I right clicked, "Edit Flat Pattern Definition" and choose the alignment side so it's not randomly rotated.
- I open my idw, dimension everything on my flat pattern. The hole table it a bit finicky, and found that punches, you have to include "Punch Center" / center points / "Center Marks" when inserting the view. Then as a workaround, I have to physically add Center Marks to each hole. Then create the hole table. (again including center mark options)
- Final Result:
So here's the issue.
If I return to the .ipt and roll back my cuts and edit some holes or add cuts, I receive the error
I accept the error b/c I know I'll roll it back to end and everything will be fine. But when I do. Everything on the flat pattern becomes messed up and all the punch centers will not return and I can't get them to come back on the idw.
My troubleshooting attempts were:
- idw: I turned off and on the view setting for Punch Centers and still broken.
- idw: Manually re-adding center marks directly and it wouldn't do it. (But the round holes would let me.)
- idw: Deleting the flat pattern view and creating a new view and still broken.
- idw: I created new hole tables and still broken.
- idw: I created a new idw and place the flat pattern with Punch Centers and still broken. (which means it's the ipt from this evidence)
- ipt: Deleted the flat pattern and generating a new one and still broken.
For my project, I needed to build this quick, so I gave up and made a new .ipt and made all the changes up front without folding and no flat pattern until the very last step and it worked just fine!... But now I'm terrified that this will happen again if I need to edit it....
AND IT DID!
There is clearly something wrong... can anyone else confirm this is a bug / glitch? or am I doing something wrong?
Almost solution?: I tried right clicking the flat pattern in the ipt and picked "defer update". This looks to break the link so you can modify without that error. I did this and made my changes once and it worked! The next however it still broke...
Model States is not a replacement for iParts / iAssemblies. It does not have all the same features yet and does not communicate well with our large currently in use libraries. 😞 https://forums.autodesk.com/t5/inventor-ideas/model-state-support-tabulated-parts-list/idc-p/11360616
