- Mute
- Permalink
- Report
I'm struggling to get a sketch to extrude to a surface. It's probably easiest to show via a couple of images, so basically Image 1 shows a successful extrude to the surface, however, Image 2 shows this fails once the sketch profile is extended to the match that of the surface (or slightly inset). I suspect the issue is to do with the circular sections at either end of the surface (as this seems to be the point at which the extrusion doesn't work).
I've also attached the IPT.
Any assistance in getting the extrusion to work would be much appreciated.
Kurt
Link copied
