Trimmed Surface
Trimmed Surface
poss08LGL7D
Trimmed Surface
poss08LGL7D
Hi All,
Hoping for some help with a workflow.
Im manufacturing a set of stairs that run straight and then curve.
I need to make a plate (sheetmetal for flat pattern and rolling later) that follows the inner profile of the stairs, but has a 40mm upstand projection, Im not cetain how to acheive this so any support would be greatly appreciated.
Screenshot of the upstand attached and the ipt file Im using with the treads modeled and a surface (thicken afterwards) is where I got to before needing experts help!
kacper.suchomski
Hi
This is an example of a simple intersection, so you will need to use a logical operation.
(view in My Videos)
Kacper Suchomski
CGBenner
@poss08LGL7D
Hello, and welcome!  Thank you for sharing your file. Can you tell us what version of Inventor it was created in?
Chris Benner
poss08LGL7D
Hi Chris, thanks for the welcome - the file was created using 2026
poss08LGL7D
Hi Kacper -nice work!
That is pretty much what I want, but cant follow along your vidoe as I can only read English, any chance you could do in English ?
Thanks so much for showing that it can at least be done 🙂
kacper.suchomski
Icons and command panel layouts are universal across all language versions.
You must use your attention and concentration to learn and achieve your goal.
Kacper Suchomski
