Trim Projected Lines
Message 1 of 8
I am projecting a complicated shape, but I can not trim the projected line. Can anyone plz tell me how to trim projected Lines?
Replies (7)
Message 2 of 8
mdavis22569
Welcome to the forum ...
You should be able to trim some types of projected lines ... it just depends on what kind.
I know you can project a regular projected line, but not an adaptive one, as you can see in the screencast.
Depending on how complex the projected line, I'm guessing this would be the case too
Are you able to share the files that you're having an issue with?
Mike
Mike Davis
Message 3 of 8
SBix26
You can't trim projected geometry.  But I suggest that you set the projected geometry to Construction, then place a new line constrained to the construction geometry and trimmed as you wish.  This workflow has additional benefits, too-- if a change you make in the "complicated shape" breaks the projected geometry, you merely have to project again and re-constrain your line, you don't lose the whole feature.
Sam B
Inventor Professional 2016 R3 SP1 Update 1
Vault Basic 2016 SP1
Windows 7 Enterprise 64-bit, SP1
Message 4 of 8
mdavis22569
I'm confused ..
You can see in the video you can trim the lines that I'm projected as long as I hold the control and they weren't adaptive
Mike
Mike Davis
Message 5 of 8
SBix26
@mdavis22569 wrote:
I'm confused ..
That makes two of us!  I can't tell in your video what is the difference in projecting the line the first time vs. the second?  The first time results in a line that is not associative (it's not yellow).  In a part file sketch (not edited in context in an assembly, so no adaptivity possible), projected geometry is not selectable when using the Trim command.
Sam B
Message 6 of 8
mdavis22569
the 2nd one is Adaptive ...
first one is just a line projected
Mike Davis
Message 7 of 8
SBix26
How does the first one end up not being associated to what it's projected from?
Can you do this in a stand-alone part?
Sam B
Message 8 of 8
mdavis22569
Ding ding .... @SBix26 no I can not
That's the different.
So it's a yes and a no answer to the question asked
You can during an assembly from another part as long as it's not adaptive.
You can NOT do it in a stand-alone part. The line will be yellow and unable to be trimmed
Mike Davis
