Announcements
TRIM IN 3D SKETCH
lkirit2000
TRIM IN 3D SKETCH
lkirit2000
Hi
Please see the attached image and CAD file. I need to trim the lines as shown in the red colors.
How to trim this projected line ?
When do curve intersection, it selects all the lines continuously. Is there any wa, that we can select indivually ?
Xun.Zhang
Hello @lkirit2000,
You can't trim projected geometry, please remove the projection firstly.
Steps:
1. Show all constraint
2. Select the one you want to move
3. Delete it in the context menu
Now you are able to trim it.
Video for your reference.
https://autode.sk/2PFX7U3
Hope it helps!
Xun
lkirit2000
Hi Xun,
Thanks for your response. Please see the attached file, this is done with out removing the constraint by the Autodesk Forum last week. I couldn't understand how  it is done. The reason I am asking is in the future if any complex 3D part modelling comes, I can do my self without asking.
Rgds
Xun.Zhang
Hello @lkirit2000,
It is just delete that line and recreated without projection.
That's the same.
Hope it helps!
Xun
